Hydraulic over-fill
/ Hydraulic over-fill #1
rdam
North Florida
Kubota 3240 DT
Checked my new L3240 (DT, 8x8 Shuttle) after the first 5 hours of use and found the Hydraulic/Transmission fluid level was a little high. About half the total distance between the marks, above the high mark. Fluid is clean with no apparent foaming. No apparent leaks or overflow anywhere. Unit now has 10 hours on it. Any potential damage or performance issues I can look forward to?
/ Hydraulic over-fill #2
I assume that the L3240 is like my L3130 with a vented transmission case. I would not worry about the slight over fill since there can not be any over pressure generated to force fluid out through seals. If you remove your loader from time to time you will lose a little fluid each time you disconnect the hydraulics.
Vernon
Vernon
Thanks. Pretty sure it's the same machine with some sheet metal changes.
New/Unused Quick Attach Backing/Mounting Plate (A65583)
New/Unused Quick...
2022 EZ-GO ELITE...
2005 Volvo VHD Roll Off Truck, VIN # 4V5KC9GF75N395481 (A65563)
2005 Volvo VHD...
2018 Ford E-450 Shuttle Bus (A61573)
2018 Ford E-450...
JOHN DEERE 4230 TRACTOR (A64277)
JOHN DEERE 4230...
213121 (A64276)
213121 (A64276)
