Hydraulic Oil
/ Hydraulic Oil #1
Spiffy
Veteran Member
SD
PT2445; several ag machines and classics
I know, espcially considering the improvements some have seen with synthetics, this has been discussed to death, but since I'm looking at straight hydraulic oil, thought maybe a new thread was warrented.
Anyway, my FIL (a tractor mechanic) was telling me that even on machines that recommend motor oil, the first thing they do is drop it out and run "hy-tran" (actually I think AG-Master is their brand). I guess mutli-viscosity, espcially detergent type, tends to foam in high pressure pumps, causing reduced power, higher temps, and shorter oil life.
I looked at the Ag-master stuff, and I'm pretty sure it's way too thin, but I saw some straight 40 non-detergent hydraulic oil at TSC, and got thinking it could be the answer. Now being single viscosity is that too heavy? Wrong altogether?
Side note, I have a leak to hunt down. Hope it's just a fitting I forgot to tighten, but we'll see. I noticed the advice in another thread to use soapy water and wash it out good first; looks like a good idea!
/ Hydraulic Oil #2
IMO, the straight 40 weight would be far to thick for trying to start the PT in your cold winters. Remember, the pumps are pumping all the time, even when you're just cranking the engine over....
I'm running 20W50 Amsoil and others are running 15W50 Mobil 1 -- and we all seem pleased with the change.
/ Hydraulic Oil #3
I am thinking of the same thing. I was told by a hydraulic tech that a single weight oil would work better in warm climates. The reason for the non-detergent is that if you do get water in the hydraulic tank or system, it will go to the bottom of the tank and stay there. Seems logical that non-detergent oil will not mix with water, therefore , no foaming.
Most people frown when I tell them that the hydraulic system uses regular motor oil.
No one seems to have a good answer why motor oil is used in the hydraulic system, after many thousands of hours have been used to determine what is the best hydraulic oil to use. Motor oil was not considered The idea that motor oil is cheap and can be found just about every where, just is not a good answer. I wonder if the manufacture of hydraulic equipment will warranty their systems if you use motor oil instead of the required hydraulic fluid.
I would suspect that motor oil is on the bottom of the list for use as a hydraulic fluid..
To fill a 20 gal tank of synthetic oil would cost around $200.00 To fill a 20 gal tank of motor oil would cost about $60.00 Who has the answer. If you do, let the rest of us know. I have been skeptical all along of motor oil in my system, but it does work. Does it work better than a good hydraulic fluid. I surely don't know. I have read most of the reports on the synthetics, and why they are the best, I am still not convicced. Why don't all manufacture of hydraulics equipment. specify the synthrtic product as the primary fluid, also, why are we having to guess wheather we will use synthetic motor, or synthetic hydraulic oil. Some of the synthetics are not 100% synthetic but they get away with calling them synthetic?
You all chime right in, I am sure you will.
It is still the owners choice.
/ Hydraulic Oil #4
Spiffy,
I agree with KentT that straight 40 Wt is probably too viscous for your apps, and would probably be brutal in Winter.
For a frame of reference, PT "recommends" 15W/40 motor oil for the hydraulics. (At least that's what the decal says on my machine). A 15W/40 corresponds to ~ISO68 viscosity when comparing with hydraulic oils.
A good reference comparison chart can be found {HERE}. If you will also look {HERE}, there is a helpful chart which shows the effect of temperature on different ISO grade hydraulic fluids. The reference temperature for the ISO grades is 40 deg C (~104 deg F), so one must be careful to look at the viscosity at the ranges one expects in their own hydraulics; 40 degrees is not a very "practical" reference temperature. In hot weather, our hydraulics may be in the 180+ degree range.
I discussed the possible changeover from motor oil to hydraulic oil with knowledgeable hydraulics folks, and ALL of them recommended using nothing less than an ISO68 hydraulic oil (our Winter temps are nowhere as cold as yours, so you may need to consider a lower ISO grade if you do a lot of winter work and do not have a heat source to keep your hydraulic oil above 20-25 degrees F.
I am planning to do the changeover when I reach ~150 hrs on the machine. I have dismissed Amsoil ATH as I consider it too thin at 5W/30 (ISO32). Right now, I have to admit that I am leaning to using a multi-grade Group IV synthetic motor oil for the change. I've not been able to sort out any special advantages of the straight ISO grade hydraulics (synthetic or not). The chemistry of the "additive packs" for these motor and hydraulic oils is mind boggling and that's where any performance (foaming, etc) and longevity differences will be seen. I have heard many times that the best performing hydraulic fluid is ATF precisely because of its superior additive pack. However, I 'm not quite ready to pop for 10 Gal of syn ATF. /forums/images/graemlins/grin.gif
J_J said: </font><font color="blue" class="small">( Some of the synthetics are not 100% synthetic but they get away with calling them synthetic?)</font>
What a can of worms that one is! The thorny issue of when is a non synthetic legally able to be called a synthetic has been discussed in the TBN lube forum from time to time. It dates back to about 1997-98 when Castrol stopped using polyalphaolefin (PAO) base stocks purchased from Mobil (the original basic component of "true" synthetic oil) in their Syntec oil. Castrol started to use much cheaper hydroprocessed petroleum base oils from Shell. Naturally, Mobil Oil complained to I believe something like the Council of Better Business Bureaus, which ruled in favor of Castrol, specifically allowing Syntec Motor Oil made from Shell ultra-high viscosity index petroleum oil to be labelled and sold as "synthetic."
To be fair, the manufacturers of PAO-based synthetics are not selling us a pure PAO product either. /forums/images/graemlins/blush.gif Somewhere in the fine print, manufacturers will point out that their oil is "fully synthetic, excluding carrier oils." The carrier oils are the oils in which the additive packs are dissolved. They constitute generally 10-20% of total product on a wt/wt basis. Bottom line is that even Group IV synthetics can have up to 20% dino oil in them. It's a rough world out there /forums/images/graemlins/confused.gif
It's quiet. Everyone in the house is asleep and I am afraid that I've run on too long....my apologies.
/ Hydraulic Oil
I had a few more questions about oil temps and pressures, so I spoke with Terry at PT today (I still give PT much credit for their friendly people). He said they use engine oil because it's the right viscosity, and any heavy duty engine oil would work fine (thus non-detergent engine oil might be an option). He also said they have little trouble with foaming; I wouldn't have noticed had the FIL not mentioned that, and of course the next day I noticed it does foam some.
Around here we have nasty temp swings which can draw moisture into the tank, so the non-det would make sense. However, maybe mulit-viscosity does make sense to combat the temperatures. If we never had it below 60F; I'd definitely look at straight 40 hydraulic fluid. Somehow seems to make sense to use oil formulated for 1000 to 5000psi; on the other hand maybe motor oils do handle PTs temps better.
Ironically, I remember IH touting hytran fluid that was supposed to be able to take on water without foaming (back in the 1980's); may have been a gimick though.
As a side note; I learned the fan setting is around 120F with 140 up to 160F normal running temps. Also, I always thought that the two high pressure ports were left and right (so I only checked left, the right being slightly less convienient under the linkage); but they are forward and backward.
I think I'll keep my options open, but look for a non-det in either an engine or hydraulic oil.
/ Hydraulic Oil
Great info tracdoc! Thanks for the charts too.
Ahhh yes, the synthetic/psuedo-synthetic debate; for hydrualics, I think I'll stay out of that one by sticking to dino motor oil vs. hydraulic oil; but can't argue reading about the many PT owners here that seem pleased with the synthetic.
I do think my final choice will be of the non-detergent type though. Also, I just looked it up; CNH still does have that hytran fluid; didn't check if the viscosity or temp range was compatiable.
/ Hydraulic Oil
A couple more good web pages:
Detergent in Hydraulics
Hydrualic Viscosity
Essentially, both articles say higher temp/viscosity range is the reason for motor oils. The first one quotes a mechanic saying that detergents should never go in hydrualics (for the same reasons I heard) but further states, if the viscosity range is needed it may not be entirely detrimental using modern detergent oils in modern pumps.
I'll need to do some looking at the AVH lubes, but may even stick with the same 15-40 (an advantage being no worry of doing a perfect flush). /forums/images/graemlins/crazy.gif
Oh it turns out that Hytran is a bit thin for me anyway, but stumbled across it's JD equivalent Hy-Gard which also cross-refs Super UDT - even if that is right (and I don't know it is), I don't think I'll be telling the orange guys /forums/images/graemlins/grin.gif
/ Hydraulic Oil #8
Yesterday I changed my Hyd oil in my 1430 with 400 hours. The old oil (10w40)had no foam in it, but the new 10w40 now has foam in it looks like foamy beer after I purged the system . The only reason I put 10w40 was it is under warrenty still. Is foam normal? Is water in the system? I called power trac and talked to Terry he said it would be fine ,I just would like another opinion. I also put a corked gasket on the top of the hydraulic tank with gasket seal the the one from the factory was hardly there I think it was #2 gasket sealer only. Thanks for any info
/ Hydraulic Oil
400hrs and still under warranty? Getting some seat time! /forums/images/graemlins/cool.gif
If it's really foamy, I wonder if you don't need to purge the main pump (charge pump port) a little better.
Else, you might have a little moisture, but from what I'm reading, nothing to loose sleep over. See if it settles overnight, and doesn't come back when you run it again.
It seems that nobody does stock the AWH (multi-grade hydraulic oil) around here; actually looks like synthetic is even more readily available. Unless in a warm enough climate to use single weight; perhaps 15W40 or synthetics are the best options.
I'm planning to stay with the 15W40 for now, but keep my eyes open for options.
/ Hydraulic Oil #10
Just thought offer this up for comments.
From a post long ago, I could not find it, we talked about hydraulic oils in the PT. It went along these lines. (I still have most of the text since I would write my posts off-line and then copy/paste into the post text box. Charlie sent this in an e-mail to PT, but I'm not sure he heard back). Use of either a 10W-30 or 10W-40 viscosity oil, with a diesel API 'C'rating (Diesel engine oil), not necessarily the API 'S' (gas engine oil) rating. Whether it is synthetic or not, the API 'C' rating appears to be important. In Case skid steers, their hydraulic oil system is 10 gallons, similar to our PTs. They specify an API 'C' rated 10W-30 oil with one quart of Case HTO (hydrostatic oil transmission) additive per every 5 gallons. Apparently the Case HTO additive makes the diesel rated crankcase oil suitable for use in hydraulic systems.
Has anyone else heard of the Case HTO additive. I was contemplating on using Shell Rotella T 5w-40 with Case HTO additive when I do my change over. Would like more opinions though.
Duane
/ Hydraulic Oil #11
Duane,
I add Shell Rotella T 5w-40 after hydraulic oil filter changes and to make up lost oil. I drained the tank once to replace the PTO solenoid and added a couple gallons of Shell Rotella T 5w-40. The hydraulics work fine and it seems to start easier in the winter with the Shell Rotella T 5w-40. When I change my hydraulic oil I plan to use half Shell Rotella T 5w-40 and half regular 10w-40. I have 450 hours now and plan to change oil at about 500 hours.
Dale
/ Hydraulic Oil
5W40 synthetic or 15W40 dino?
Duane, I noticed the additive too when I was looking at HyTran; sounds like a great plan to me if you're using regular engine oil. Not sure if it'd help, hurt, or do nothing for synthetic.
Dale, is there an advantage of mixing instead of going all 5W40? I'm thinking that would help combat these winter temps; and it should perform the same at operating temp as the blend (40 weight on both), but I might be missing something too.
FWIW, the data I stumbled across last night while searching for non-detergents told me two things: 1. Amsoil is the most highly advertised, published, and generally discussed oil product on the web. 2. The viscosity and shear data sure do look tempting for the temps in a PT's hydraulics (with Mobile 1 being right in there too). However, partially to spite fact number 1, and in keeping with my earlier thoughts, it's status quo for now. /forums/images/graemlins/grin.gif
/ Hydraulic Oil #13
Chad,
I don't have a technical reason for mixing the two oils. The original oil in my PT seems a bit thick for easy winter starting. So, I started adding synthetic make up oil and observed easier winter starting. Watching the posts got me thinking the 5w-40 shell might be a little light for my aging pumps and motors. But, I don't know. Maybe I will try 100% 5w-40 synthetic shell replacement and see how well it works. I have several months to think about non-technical reasons to do either.
Dale
/ Hydraulic Oil #14
FWIW, the data I stumbled across last night while searching for non-detergents told me two things: 1. Amsoil is the most highly advertised, published, and generally discussed oil product on the web. 2. The viscosity and shear data sure do look tempting for the temps in a PT's hydraulics (with Mobile 1 being right in there too). However, partially to spite fact number 1, and in keeping with my earlier thoughts, it's status quo for now. /forums/images/graemlins/grin.gif )</font>
It was the viscositiy & shear index that swayed me to go with Amsoil 20W50 instead of Mobil 1 15W50. Plus, the Amsoil was slightly less expensive, delivered to my door than was the Mobil 1 from Walmart. Note that 15W50 Mobil 1 is about $5 a gallon more expensive than the other Mobil 1 blends -- at least last summer when I was looking -- about $25 a gallon. I think I paid a little around $22 a gallon for the Amsoil.
/ Hydraulic Oil
Since the PT operating hydraulic operating temp is [I think; 160 vs 212?) lower than the "at temp" rating on a multi-viscosity, you might bit just a bit thicker mixing in some 10W40. The shear ratings on 10W40 may negate it though; these guys already using synthetic would know much better than I! /forums/images/graemlins/blush.gif /forums/images/graemlins/smile.gif
/ Hydraulic Oil
</font><font color="blue" class="small">( It was the viscositiy & shear index that swayed me to go with Amsoil 20W50 instead of Mobil 1 15W50. Plus, the Amsoil was slightly less expensive, delivered to my door than was the Mobil 1 from Walmart. Note that 15W50 Mobil 1 is about $5 a gallon more expensive than the other Mobil 1 blends -- at least last summer when I was looking -- about $25 a gallon. I think I paid a little around $22 a gallon for the Amsoil.)</font>
/forums/images/graemlins/cool.gif Maybe I can read oil charts right! /forums/images/graemlins/grin.gif At $22/gallon though, I better stop whining about the $6.50/gallon if I stick with 15W-40.
/ Hydraulic Oil #17
Yes I use my pt aalot but it beats paying laborers. My oil did return to normal after I ran it for 10 minutes it looked like oil again. And my hydraulic tank does not leak with dirt collecting around it any more. Also my tank hold 15 gallons and i found a machine shop that use the old oil to run their furnace. The recyle truck only picks up 6 qt a week
/ Hydraulic Oil #18
Thanks everyone for all the resource material. This will keep me undecided until the last possible moment. /forums/images/graemlins/grin.gif
FWIW, I'll toss another couple of candidates into the ring.One is Kubota Super UDT, which runs around $76 for a 5 gal pail {HERE}. I have had difficulty finding the specs for it, but there was a dicussion thread on it in the BOBISTHEOILGUY forum {HERE}, which noted a viscosity index of 140.
Another consideration would be one of the Schaeffer Oil Co. synthetic hydraulic blends, such as their #254 {HERE} which comes in several ISO grades of 32 to 220. Another product is their #315 Simplex Supreme transmission/hydraulic fluid {HERE} and{HERE}, with a VI of 150. Schaeffer is one of the oldest oil companies around. Their retail sales are limited, but you can readily purchase direct or in smaller quantities from one of their dealers who maintain a presence on the BOBISTHEOILGUY forum. I like the specs on #315, especially its high VI, meaning less viscosity change with temp change.
/ Hydraulic Oil
<font color="blue"> This will keep me undecided until the last possible moment. /forums/images/graemlins/grin.gif [c </font>
I'm guessing that for my running temps (dead between the usual 40C & 100C specs), the HyTran, Deere, UDT, etc will be a bit thin. My take is that the right combination will be maybe around 80csp @ 40C and 15csp at 100C. But I'd love to see a bunch of options overlayed temp/viscosity and see just what we are looking at around 70C. Also, the shear would need to be part of the equation, but I sure don't know how they'd weight.
If I were in a warmer climate; I'd almost bet that any of the UDT, Hytran, Deere, other cross-refs, in an iso100 would come out very nice; but again I'm just pulling numbers from the mental interpolations of vague memories of various characteristics discussed in this thread over the last week. /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif
Thinking there might be a little merit to the Hytran motor oil additive, but maybe it's a gimmick.
/ Hydraulic Oil
Check out the specs on the AWK; if I'm reading it right it has higher high temp viscosity, and lower cold temp viscosity than regular motor oil (maybe some of the sythethetic formulas too), and is high shear resistant and antifoaming as well!
AW Series
That said, I don't think they sell AWK anymore (I cant find it anyway) I'd love the AWJ for winter use, but would like just a bit higher high temp viscosity for summer, though if the shear specs are good enough maybe not an issue.
Either way, I'm status quo for a while, but thought I'd let you guys bat it around. /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
2019 Polaris Ranger Crew XP1000 4x4 Utility Cart (A61572)
2019 Polaris...
2016 Ford Escape...
Tree Boom Skid Steer Attachment (A61572)
Tree Boom Skid...
2017 Nissan Juke SUV (A61574)
2017 Nissan Juke...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
