Hydraulic oil
   / Hydraulic oil #1
Lazy
Platinum Member
Missouri
ford 1920 w/fel and bh, case 470, allis chalmers B 1937, JD 450 track loader, Case vac, 3 cub cadets ford lgt 125, Kubota 2230/60 inch mower.1948 farmall cub 1953 farmall cub
Hi
Anyone here use Coastal hydraulic oil? If I read the spec's on the can correctly I should be able to use it in my Case,Ford,Allis, and JD tractors. it would make it a lot easier than buy all the mfg. oil. Any thoughts on the coastal oil verses the mfg brand recommended in each of the mfg.manual.
here is a link to the spec sheet for the oil.
Charlie
   / Hydraulic oil #2
There are lots of universal transdraulic oils out there. For instance.. the UTF that tractor supply sells meets the specs for about 20 tractor manufacturers.. including hyguard.. hytran.. jd 303, and NH m2c134d... etc.
Do not confuse this with straight.. plain hydraulic oil.. like for a floor jack... two different beasts..
I run the TSC UTF in my NH 1920, and my 2n, 8n, and NAA
Soundguy
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
Adams 5T High Clearance Fertilizer Spreader (A55301)
Adams 5T High...
