Hydraulic Oil Temp
   / Hydraulic Oil Temp #1
buzzsaw07
Western Pennsylvania
Massey Ferguson 1734e
I have a MF 1734e with FEL. I never payed much attention on how hot the connection got at the loader valve. I noticed the connections and valve body were about as hot as a cup of hot coffee. I do not have a thermometer to get a temp. You can hold on to the connections but not for an extended length of time. Is this too hot? I see that the temp should not be above 180 degrees and some post say 100 degrees plus the ambient air temp.
   / Hydraulic Oil Temp #2
If you can touch it it's not to hot.
   / Hydraulic Oil Temp #4
Normal operating temp for hyd oil is around 100° + ambient temp.
   / Hydraulic Oil Temp #6
I don't know about my tractor. Don't have a thermometer that reads that high. The Taco Wagon has digital dashboard display for just about every fluid in the truck. The other day - 300 mile run on I-90. Tranny oil temp - 157F. Coolant temp - 210F. Engine oil temp - 182F.
   / Hydraulic Oil Temp #7
There is some conflicting information on the matter, which may be due to the additives in the oil, but generally experts say that conventional oil has a life of ~10,000hrs at 140°F/60°C and every 18°F/10°C rise above that cuts the life in half. This of course assumes the limiting factor is oxidation and not a contaminate like dirt or water.
158°F ≥ 5000 hrs
176°F ≥ 2500 hrs
194°F ≥ 1250 hrs
Vickers Mobile Hydraulics Manual, page 372, section 'Heat or thermal contamination': "Their useful life, as well as maintenance of viscosity, chemistry and the other attributes is based upon continuous operation below a critical temperature. This critical temperature is 140°F. Every 18°F increment higher than 140°F effectively doubles the oxidation rate of the hydraulic fluid (petroleum based) thus cutting its useful life in half, e.g. running a system at a consistent 176°F would reduce the useful life of the fluid by 75%."
Oil Hydraulic Systems, by S.R. Majumdar: "As a working rule oxidation rate is doubled for each 10°C/18°F rise in the temperature. An oxidation-inhibited high viscosity index (HVI) oil may give a useful life of ~100,000 hours at 40°C/104°F even under the condition of aeration and catalysis. When the oil temperature is raised to 60°C/140°F, life drops to as low as 10,000 hours."
Synthetic oil doesn't start to break to till at least 170°F or higher depending on the base stock and additives
Hoses and other rubber components are generally good till at least 212°F/100°C depending on the compound. But similar to oil, the hotter they run the shorter the life.
ISZ
PALLET OF SITE FENCE STABILIZERS (A51248)
PALLET OF SITE...
UNUSED WOLVERINE BC-13-72W-72" HYD BRUSH CUTTER (A51248)
UNUSED WOLVERINE...
2013 Chevrolet Malibu Sedan (A51694)
2013 Chevrolet...
UNUSED SWICT 66" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 66"...
MIDEA 8000 BTU WINDOW AC UNIT (A51248)
MIDEA 8000 BTU...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
