Oil & Fuel hydraulic oil question
/ hydraulic oil question #1
ymurf
Bronze Member
Could someone tell me if Shell Tellus 32 hydraulic oil is the same as aw32? I am changing the oil in my Farm Pro 2425.
/ hydraulic oil question #2
That depends. AW32 is a generic rating for minimum standards established by the International Standards Organization (ISO), and adopted in whole or in part by the Society of Automotive Engineers (SAE), and the American Petroleum Institute (API). Petroleum distributors will have literally dozens of different brand labels under which their products are marketed, some with identical additive packages sold at a wide margin. AW denotes Anti-Wear additives included at no extra cost. But be informed that there is a big difference between AW hydraulic oil and AW machine oil. Both can be used in a hydraulic system, but usually only the AW hydraulic oil has equipment manufacturers endorsements.
So, to answer your question specifically: Yes and No.
It's not technically going to make any difference in your application. You should be just fine.
Thank you for the answer.Good stuff to know.
Bob Rooks said:
Yep. That info and $2.00 will get you coffee at Denny's.
Well if your ever in Steelville Mo. Give me a shout.I owe you a coffee.
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
1453 (A57192)
1453 (A57192)
2008 Lexus IS250 Sedan (A61569)
2008 Lexus IS250...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Isuzu FTR Landscape Dump Truck (A61568)
2018 Isuzu FTR...
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
