Oil & Fuel hydraulic oil or transmission problem
   / hydraulic oil or transmission problem #1
bdm123
MF135
Hi,
I have an early '70s MF135.
The problem is a few new behaviours:
When it gets "stuck" when dragging a scraper blade, one or both wheels used to continue to spin, now they just stop.
In high range, I must step through the gears - 1st, 2nd, 3rd where before I could start in 3rd high, it would just labour a while until it got up to speed. Now it just wont move when starting from a full stop in 2nd or 3rd high.
Is this a hydraulic oil problem, like water in the oil, or is this a worn out transmission?
The hydraulic oil looks sort of creamy and bubbly. I suppose I should change the hydraulic oil anyway, but is that only part of the issue?
   / hydraulic oil or transmission problem #2
I'm no hydraulics expert, but as far as I know, if the fluid looks anything other than slightly brownish or clear, with no bubbles, there's definitely a problem, most likely contamination.
Sounds like water, air, or both in your case. Definitely get it out of there. Throw on a new filter as well, then watch closely. Don't forget intake screen, if the 135 has one.
Your symptoms are right in line with lowered hydraulic pressure and/or flow, which would result from contamination. Let's hope the pump & transmission are OK!
   / hydraulic oil or transmission problem #3
Sounds like a clutch problem to me unless you have a multi-power transmission. Also sounds like water in the oil. I would change the oil, clean the screen and use only Permatran oil if you have the multi-power transmission. Also check the boots around the gear shifters as this is where water can get in oil.
   / hydraulic oil or transmission problem #4
Hi,
Your clutch is either completely shot or it needs an immediate adjustment....Don't use the tractor any more till you at least attempt adjust it....BobG in VA...
   / hydraulic oil or transmission problem #5
Sounds like clutch is out. The fluid doesn't have anything to do with the drive.
The transmission has water in it. I would replace the fluid with some cheap fluid and work it until it is warmed up and then drain and put Permtran back in.
378665 (A51573)
378665 (A51573)
22ft T/A Enclosed Cargo Trailer (A51694)
22ft T/A Enclosed...
BESTWAY LOT NUMBER 40 (A53084)
BESTWAY LOT NUMBER...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
2016 LINK-BELT  235X3 SPIN ACE EXCAVATOR (A52472)
2016 LINK-BELT...
