Hydraulic Oil Leaking from underneath my Bobcat 341
   / Hydraulic Oil Leaking from underneath my Bobcat 341 #1
SN Graham county
Robbinsville, NC
Bobcat 341
I noticed the other day when i went to walk the excavator across my property and it left a trail of oil behind me. So i took the bellypan off and I cant tell much but it is leaking out fast is their a seal or gasket that could be busted?
   / Hydraulic Oil Leaking from underneath my Bobcat 341 #2
You could have a leak from just about anywhere, from fittings to hose, pump, hyd motor, etc.
Get it off the ground clean everything, and then run it for a while looking for the leak. Wear eye protection.
NAPA makes a leak detector that you add to the hyd fluid and it will mix in and flow out the leak point. When you shine a black light on everything, the leak should show a greenish yellow.
Do this in a dark area and you should be able to see the leak. If you find the leak, fix it, and clean everything again and wait for the next leak, using the black light often.
Amazon also has the dye.
http://www.amazon.com/Tracer-Products-TP34000601-Fluorescent-Detection/dp/B000JFHNTM
http://youtu.be/QMEMYx9kkBo
   / Hydraulic Oil Leaking from underneath my Bobcat 341 #3
Have a 341 Bobcat excavator and the rod just broke in the arm hydraulic ram, when I fully extended the arm during erxcavation. Trying to figure out whether this is equipment or operator failure. Anybody have similar experience??
Wright Self Dumping Hopper (A55787)
Wright Self...
2017 Ford F450 Service Truck (A55788)
2017 Ford F450...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
2010 Hyundai Elantra Touring Sedan (A54815)
2010 Hyundai...
UNUSED LANDHONOR LHR-RF24 RATCHETS & TOOLBOX (A54757)
UNUSED LANDHONOR...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
