Hydraulic oil leak
   / Hydraulic oil leak #1
Uniblab
Waterloo, IL
Deere 2320
I have a 2011 Deere 2320. I noticed last year it is leaking hydraulic oil from somewhere underneath. I had it home for the winter and tried to see where it was coming from. I checked all the bolts and drain plugs all were tight. It seems to lose it when the mmm is running. I cleaned the oil up but after mowing it is slung all over so I still can't pinpoint the source. I don't think it's the mower pto seal, it looks dry. Looks to be oily on the left side of xmission. Thought maybe someone here had a similar problem. Thanx!
Well I cleaned underneath and didn't see anything like that. I keep the mower pto hooked up all the time anyways. After I cleaned it this winter and filled it it didn't leak until I mowed for the first time Friday. It's so messy under there I'll have great time trying to find where it's leaking. Dealer is my absolute last choice. They're pretty proud of their labor rates.
   / Hydraulic oil leak #4
Not sure from what you said about cleaning it underneath, but sounds like time to clean again.. then keep a close eye on where that oil is coming from to pinpoint what is leaking. You can earn that money that the dealer will charge.
By chance did you over-fill it?
No I didn't overfill. It drops in the sight glass when I use it. By cleaning I meant washed the oil off with solvent and blew it off with air. It only appears to lose oil when mmm is running so it's hard to tell where it's coming from as it slings it all over and I don't see a dripping from anywhere when I look. The shaft and seal for the mid mower appear dry so that's even more of a mystery. Might have to disconnect mower shaft and run pto by itself and see if I can spot anything.
Well after taking the leaking tractor to the Deere dealer and $1,300 and 3 weeks later they found the leak. Gasket was cracked between hydro pump and xmission and leaked like a sieve when oil got hot. Had to disassemble half the tractor to access it. They said they'd never seen that before. I said if it's gonna happen to someone first it's gonna be me!
   / Hydraulic oil leak #7
Sorry to hear the expensive outcome. Appreciate you following up with the results for the archives.
2025 SDLANCH SDLD25 UNUSED Crawler Dumper (A53117)
2025 SDLANCH...
2020 Chevrolet Express (A50123)
2020 Chevrolet...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
2015 Jeep Wrangler Unlimited Sport 4x4 SUV (A51694)
2015 Jeep Wrangler...
2015 Skyjack Scissor Lift (A53117)
2015 Skyjack...
2018 Forest River Grey Wolf 26RR Lmtd Toy Hauler (A52384)
2018 Forest River...
