Hydraulic oil in otor oil
   / Hydraulic oil in otor oil #1
OhioJLP
Grover Hill, Ohio
Cub Cadet
My son-in-law bought a used TYM T280 w/ loader, First all the plastic on the hood and side panels cracked and fell off, now the hydraulic oil runs into the motor oil. You don't even have to start the engine. I don't mind fixing older tractors( 2000 model), but when the company will not even acknowledge they made this tractor, that becomes a problem. I have contacted a TMY dealer, they cannot find any info on it, like a parts, service, or repair manual. Their request to TYM for info has been met with silence, nothing, not a word. The basic tractor, motor( Kubota D-1503-E, Hydraulics works well. I need some help. Do we just junk it? No I will not take to an auction and let it be somebody else's problem. Any thoughts
   / Hydraulic oil in otor oil #2
first, locate how hyds are getting into the crankcase. many times it is a blown shaft seal on a pump. sometimes they blow from deadheading or damaged relief / ill fitting quick connects.
T280 could also be TYM 2810, Mahindra 2810 and maybe others
   / Hydraulic oil in otor oil #4
Hello,
I apologize for the late reply, I was a few days behind on checking up on the forums.
As for the T280, that is not actually a TYM Tractor. It is a Millennium tractor, the transmission is the only thing that we would be able to help with parts on. That being said, we can not guarantee that all of the parts would work properly.(As it is an older model not within our manufacturing scope, our updated parts may not be completely compatible) So, unfortunately, we have limited information on it. However, I can help in some areas. I was able to dig up some information stored away for incidences such as this. A parts catalog from Mellenium, which features a few part numbers that we still carry updated versions of. If you would like to send me your email address through a private message, I'll be able to transfer the files over to you. I have also found a workshop manual that may help in most areas of your tractor.
Once again, we apologize for the miss-communication and I hope these will help you with your tractor!
That would great, I need all the info I can get. Please e-mail to jeffery_priest@yahoo.com. I am taking the hydraulic pump Friday to get checked out. Just need to figure out where the hydraulic pressure release valve is. Got this job on hold till it rains. Thank you very much
2006 John Deere 317 Skid Steer (A52384)
2006 John Deere...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A53472)
Koyker Loader...
(1) VISSANI REFRIGERATOR (A51248)
(1) VISSANI...
2005 Ford F-150 Pickup Truck (A51692)
2005 Ford F-150...
2012 CATERPILLAR 316EL EXCAVATOR (A51246)
2012 CATERPILLAR...
12x24 Custom Built Building (A51573)
12x24 Custom Built...
