hydraulic oil for dump body?
   / hydraulic oil for dump body? #1
lostcause
Veteran Member
Maine
i've got a ton dump with a 12v power pack driving the hydraulic cylinder for the lift on the body. i have only owned this for a few years, and i mostly use it for plowing in the winter. i put the body up to let the snow drain out of it, and realized it was pretty slow going up and down.
first, i realized i don't know what it uses for fluid in the first place, and second, i was wondering whether there is a synthetic or other fluid for them that flows better in the cold weather. since they never heat up (except from use) i didn't know whether there was a good hydraulic oil that worked well in them for year round use that performed better than standard fluid in the winter.
the body/lift is made by omaha, but that's as much as i know. i bought it used and there's a lot of rust and crud on everything, and i'm not so interested that i'll dig for model numbers in this weather. i'll wait till spring for a more thorough exam. i would have to think that anything like this will use a standard oil?
   / hydraulic oil for dump body? #2
I use an aw32 hydro oil in mine, works good year round
   / hydraulic oil for dump body? #4
The 12v power packs are similar to the 12v Monarch pumps used for snow plows. Mine was the same way, and in fact, probably much worse. My power pack was full of a brown emulsion, and the rust is so bacd that I could not drain it. I used an turkey baster to remove as much of theold fluid as possible and flushed it this was with ATF. Once clean, I refilled with synthetic snowplow fluid. It operates much better, with less battery strain now.
   / hydraulic oil for dump body? #5
I would probably use aw32 in it.. but I have heard of people putting syn atf fluids like valvoline maxlife.. or atf+4 in there. in colder climates that thin syn fluid flows darn good.
soundguy
Harlo HP5000 5,000LB Rough Terrain Forklift (A42742)
Harlo HP5000...
2005 Toyota Highlander SUV (A42744)
2005 Toyota...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A42744)
2021 Ford F-150...
2009 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A42744)
2009 Dodge Ram...
2019 NRG BLENDER (A45333)
2019 NRG BLENDER...
2018 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A42742)
2018 JLG Skytrak...
