Hydraulic oil backing up
   / Hydraulic oil backing up #1
daysailor
Fort Collins
IH 464
When my 1976 IH-464 gets hot, the hydraulic oil starts coming up through the dipstick. Not much, just enough to make a mess. This just started happening recently. I have replaced the hydraulic oil filter, but it still happens. Any ideas what might be wrong?
Daysailor
   / Hydraulic oil backing up #2
Not familar with this tractor, but my first thought is there is a vent that's plugged so dipstick has become the vent.
   / Hydraulic oil backing up #3
did you change oil type to a thicker oil?
did you overfill it?
   / Hydraulic oil backing up #4
Does your oil look foamy..??
if so, the air/foam will take up room in your hyd system and return oil will burp out the vent (similar to overfilling) when you retract cyls
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
Case Maxxum 140 (A50120)
Case Maxxum 140...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
2017 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A54607)
2017 FREIGHTLINER...
KUBOTA M7-132 (A53084)
2009 Lexus RX 350 SUV (A53424)
2009 Lexus RX 350...
