hydraulic of Yanmar 1300
   / hydraulic of Yanmar 1300 #1
lvinci
because the hydraulic of my yanmar 1300 does not raise after of a time to be working. As it is the drained cork of of hydraulic oil
   / hydraulic of Yanmar 1300 #2
I'm not sure I understand. Are you saying your hydraulic lift arms are not raising? Could a drain cork mean drain plug? Do you have anyone that may help you translate just a little better?
Just a little more information and we may be able to offer some suggestions.
Mark
Sorry but i not write very well , :eek: .
My Yanmar work well but when pass one hour the hydraulic lift arms are not raising .
Is the problem of the hydraulic oil ?.
Where is drain plug for change the hydraulic oil ?
Thanks and pardon by my form to write if they do not understand to me
   / hydraulic of Yanmar 1300 #4
The drain is right in the bottom of the transmission on the left side. It could be that your suction screen is getting clogged. I would drain the oil, clean the screen (on the right side behind the suction line) and see if that fixes it.
Aaron
Parts@HoyeTractor.com
(940)592-0181
Thanks for the advice ,Aaron.
Resolute problem
2025 CFG Industrial MX12R (A50123)
2025 CFG...
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2014 DRAGON...
BAUER ATD-750 VERTICAL HYDRAULIC PIPE HANDLER (A53843)
BAUER ATD-750...
1999 John Deere 4300 (A50123)
1999 John Deere...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A51692)
2020 Ram 1500 4x4...
