Hydraulic Multiplier
   / Hydraulic Multiplier #1
Rowski
Veteran Member
North Central Vermont, Jay Peak Area
2004 New Holland TN70DA with 32LC loader, 2000 New Holland 2120 with Curtis cab, 7309 loader
I need to expand my OEM single rear remote. I will need a total of three sets of remotes. I can not use the manual spool valves due to my cab. So I'm looking at electric multipliers. I found this company (V & M) . I can get the set up I need for $550. That includes either a joystick or control box with commercial cycle switches to activate the remotes.
I was wondering if there are any other companys that have this type of setup? I would like to compare.
Also... Any other ideas??
Many thanks!!
   / Hydraulic Multiplier #2
As you have a NH tractor, why don't you ask your dealer. I believe that the NH remotes are the cheapest to add on compared to Kubota and JD.
JD also sells electric splitters. I am not sure who makes them, however.
   / Hydraulic Multiplier #3
<font color="blue"> I found this company (V & M) . </font>
Many months ago I did a search and also came up with V&M and one or two other companies (names I've forgotten). It became obvious pretty quick, that V&M had the best selection of valve multipliers for my needs. The salesperson I talked to was very knowledgeable and patient.
I never bought the multiplier because I backburnered the project I was thinking of. I'm posting just to say V&M seemed to have a good selection of products and pleasant folks in sales.
OkieG
I have called the dealer(s). They are supposed to call me back. I don't think there is anything from New Holland. I don't have any empty slots for the the levers. Not sure if that would make a difference.
I have found some spliters. They are cheaper but only split the circuit giving me 2 remotes. I need a total of three.
Very pleasant person, I think his name is Mark. I talked to him about 2 or 3 years ago and agian this week. Prices haven't changed any. I'll see if this post brings any more replies of other companies. I need to order in the next couple of weeks. I would like to have it before my snowblower arrives in late November.
Thanks for your input!
   / Hydraulic Multiplier #6
Can I ask what's up? Sounds like your getting into a project will be attemping in the future? Planning on getting a snowblower with hydraulic rotation and chute deflector.
My TC24d has one remote for the bh. I was thinking of running 2 spool valve (No Cab) for the blower. I'm a little confused on the hydraulic line part though. The remote on the rear axle is for return I assume? So the hose from my engine that I use for the 3pt hitch needs to be split so I can run the 3pt hitch plus power the additional hydraulics?
I am very new to whole tractor thing. Thanks /forums/images/graemlins/smile.gif
Frontier LR5060 (A53317)
Frontier LR5060...
6 Cubic Yard Dumpster (A55851)
6 Cubic Yard...
(1) KUBOTA TRACTOR RIM (A57192)
(1) KUBOTA TRACTOR...
UNUSED HYD AUGER (A57192)
UNUSED HYD AUGER...
2004 Pierce Tilt Crew Cab Pumper Fire Truck (A55852)
2004 Pierce Tilt...
2023 JOHN DEERE 26G EXCAVATOR (A52707)
2023 JOHN DEERE...
