Hydraulic Motor Question
   / Hydraulic Motor Question #1
ocaj11
Northeast Texas
John Deere 5325 4wd, Kubota B7500 HST
Hello All,
I would like to get some advice regarding hydraulic motors. I would like to get a motor to mount to my front end loader and use the motor to turn drill stem for well drilling. I have a John Deere 5325 with the following hydraulic specs:
Pump Rated Output Standard 19.9 GPM
Rated Flow @ One SCV 13.9 GPM
Maximum Operating Pressure 2,906 GPM
Maximum Hydraulic Power 19.5 HP
I'm currently jetting a water well using a 4200 psi pressure washer. As I jet down, I'm inserting 4" pvc for well casing as I go down. Currently, I'm at 40 feet and I ran into some gravel that my pressure washer won't cut.
I would like to know which hydraulic motor I need to give me the greatest tourque with a fairly low RPM. If I use 1" or 1 1/4" black pipe for drill stem and get maybe a 2" drill bit and a 5" reamer bit, maybe I could push through the gravel and continue down with the drilling method or pressure washing method assuming I'm still in clay or hit sand.
I looked at surplus center for hydraulic motors, but I really couldn't figure out which type would be best for my application.
   / Hydraulic Motor Question #3
Hello All,
How are you getting the gravel up out of the well? Sand doesn't need that much velocity to flow out , but in a 4 in casing. Gravel will need some high velocity flow, and maybe not even move the gravel at all.
I have two thoughts on the gravel issue:
1. If I had a rotating bit at the bottom of the hole, maybe the gravel could be broken up and pushed into the surrounding soil far enough to allow the casing to slip through. I've never done this before, so that may or may not be possible.
2. I could rent a dewatering pump from the rental yard and plumb that up to a 1" pvc pipe that I put in the bottom of the well. Put the suction end in my lake, turn on the high volume of water, and try to lift the gravel out with the water flow.
It's a new adventure for me, so ideas are welcome....
   / Hydraulic Motor Question #5
Would not the gravel layer give you good enough water flow, or do you know exactly how deep you want to go. When you take everything out of the well casing, how deep is the water if any?
Before my 100 ft 2 in well rusted trough, the water rose in the pipe so that a 1 in, 20 ft pipe with a ft valve was sufficient to maintain good water flow. I later removed that pump and pipe, and installed a 1 1/2 HP pump on the 2 in pipe, and drew plenty of water. When it started pumping water and sand, I knew the casing was rusted through. There is a chance that I can put a pipe within a pipe and recover the well.
JJ,
My guess is that I have hit water by hitting gravel. I've dug two ponds on this place and never once hit a rock, so I was suprised to hit gravel at 40 feet. Unfortunately, by jetting the well with water, I'm left to guess whether or not the water in my bore is being drawn up by the surrounding soil or if it's flowed back into water sand? I haven't put any water in the hole for a week now and I can see water down about 30 feet. I would like to go deeper just to ensure that I have sufficient water for my irrigation needs.
I purchased some used 2 7/8 drill stem today and I'm going to put 45 feet of steel in the bore and see if I can punch through the gravel using my trackhoe for a hammer. :)
I should have an update after this weekend if things go right.
On the Hydraulic Motor question: If the motor is rated for 2500 psi and my tractor makes 2900 psi, will that hurt anything? If the motor is rated for 20 GPM and I only make 17 GPM, do I lose much?
   / Hydraulic Motor Question #7
You could dial the PRV relief down, or add a DPRV across the hyd motor. Less rpm means less speed. You will still have the torque across the speed range.
The pressure will only get that high if you stall the motor. The pressure is based on the resistance the hyd motor has to overcome. .
   / Hydraulic Motor Question #8
Keith, you REALLY need to know what the average well depth is in your area. If you are in an area with lots of springs, you may have sufficient water at the 50' level, but I'd bet you will find most wells in your area are 200' or deeper. The water you have in your current hole may just be normal ground seepage and nowhere nearly sufficient enough to pump. The gravel you have found may be an old creek bed. Under the gravel, you could find limestone or shale that is very hard. The danger of a stuck drill is very real. My neighbor had a professional driller who got a stuck pipe at about 300' and had to give up and start a new well. I understand your need for water and that you probably don't want to spend a lot of money on a driller, but without having some idea of where you are going, this may just be the first of many obstacles.
I grew up in Denton and we had rocked up shallow 30' wells fed by springs. We also had two ponds fed by springs that never dried in the worst drought conditions. I know there are lots of springs around northeast TX. You could be close to success, but who knows? Maybe you have more info than you have posted. Hope so. . . .
Edit: Let me add a couple of links that may be helpful.
Northeast TX underground water
Northeast TX Groundwater Report
   / Hydraulic Motor Question #9
As far as the motor question, if you are running 3 GPM less, then the motor rpm will be about 70 rpm less.
As the motor cu in increases, the rpm of the hyd motor decreases with the same GPM's.
   / Hydraulic Motor Question #10
Have you tried to draw any water from the well. If you are in a gravel layer, you might have enough water, maybe not drinking water, but test it anyway.
http://www1.agric.gov.ab.ca/$department/deptdocs.nsf/all/agdex639
2013 DRAGON ROLL OFF TRAILER (A53843)
2013 DRAGON ROLL...
2003 Club Car DS Electric Cart (A51694)
2003 Club Car DS...
2015 John Deere 7700A Mower (A52377)
2015 John Deere...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2016 FREIGHTLINER...
