hydraulic motor chute rotation on a bx24
   / hydraulic motor chute rotation on a bx24 #1
muskokaBX24
Port Carling, Ontario
BX24
Anyone have any thoughts as to why my hydraulic motor that I am trying to install for my chute rotation on blower only goes one way when connected to the left right of the stick for my FEL. When I connect to the up down on the stick I get perfect rotation-so I now know it is not the pump...
   / hydraulic motor chute rotation on a bx24 #2
I'm going to guess your tractor has a regen function for your curl circuit.
   / hydraulic motor chute rotation on a bx24 #3
Yes, that is the reason...but to clarify things for the OP take a look at THIS thread where I detailed the issue, and also reference a good read on the subject.
There are always LOTS of threads like this around this time of the year! Search the term "regen" for more threads to read.
The long and short of it is you have to push the joystick further to the right past the detent...
Thanks guys,
The regen was indeed the problem. Thanks again for pointing me in the right direction. At the end of the day did anyone decide what was the best solution? What is the easiest way to limit the speed of the rotation if I have to jam my stick right and cannot feather it like I can when I go left. I have not had time to work through all the threads on it yet- just the Kennyd one.
   / hydraulic motor chute rotation on a bx24 #6
Unfortunatly, I don't think there is a "solution". This is something Kubota does backwards IMHO. Learn to love it;)
An adjustable in-line flow restrictor is the best way to adjust and "fine-tune" the speed to your liking. Take a look at this link: Surplus Center
KJ 12'x20' Single Garage Metal Shed (A50121)
KJ 12'x20' Single...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
John Deere 7130 (A50120)
John Deere 7130...
Rears 1000 Gallon Orchard Sprayer (A50120)
Rears 1000 Gallon...
2014 John Deere 644K Articulated Wheel Loader (A50322)
2014 John Deere...
