hydraulic lines
   / hydraulic lines #1
jinmared
Bronze Member
Goldendale,Wa
Jinma 354 fwd
I am thinking about changing the hard hydraulic lines over to hoses, That is the line from the pump and the line to the pump. I want to change out the OEM hydraulic pump to one with larger capacity and this would make it a lot easier to do.
anybody have an opinion on this idea?
   / hydraulic lines #2
how about you throw us a bone and give us some more info to go on?
hard lines to hoses are doable. pump swaps? depends on mounting and if the valving can handle the flow.. etc.. sump size needs to be looked at as well as relief capability.
lotsa variables to considder. can't just slap a 12gpm pump on a system with a relief valve designed to dump 4gpm, or a control valve designed to handle 4gpm.. etc.. and a sump that holds 6 qts oil.. etc.. everything has to be staged to handle the flow volume..
soundguy
   / hydraulic lines #3
Jinma 354 fwd
Specs say you also have a closed center system. Is this correct.
You now have 5.28 GPM's. How much more were you considering.
Not sure if the power steering has it's own supply of fluid.
Pressure about 2320 psi.
Have you considered a PTO hyd pump? More volume if you have the HP to spare.
You have about 35 HP.
It takes about 11 HP just for your hyd sys.
http://www.surpluscenter.com/item.asp?item=9-1047-2&catname=hydraulic
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A53473)
2-Row Peanut...
2009 PETERBILT 365 (A53843)
2009 PETERBILT 365...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
1999 WABASH 48X102 FLATBED TRAILER (A53843)
1999 WABASH 48X102...
