Hydraulic lines
   / Hydraulic lines #1
richn
I am looking to replace the lins on my MF 202
It has 3/8, 1/2, and 3/4 lines
Most have a male NTP at one end and a male oring on the other end that screws right into the cylinder. Looking at the hose at suplus supply, it seems that for a give size hose the oring fillting can come in diffferent sizes ...... 4M, 5M etc, how can I determine which size I need ?
   / Hydraulic lines #2
Take the old one with you, and ask them to match it.
The fittings I have bought had what they were stamped on the outside too.
   / Hydraulic lines #3
Like Mith said most hydraulic hose fittings are marked somewhere. Not all but most. If all else fails take the old ones with you and have new ones made.
   / Hydraulic lines #4
If you want to order online here is a size chart for fittings.
You will probably need calipers to get a close enough measurement to tell one size from the other.
Discount Hydraulic Hose.com
The dash size method is just based on 16th -08 = 8/16 or 1/2.
Как зайти с телефона на кракен. kra39ac.cc  | Kraken зайти на площадку? как пополнить кошелёк? Правила диспута
Как зайти с...
New Long Forks (A53002)
New Long Forks...
2005 CATERPILLAR D3G LGP CRAWLER DOZER (A51246)
2005 CATERPILLAR...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
2015 Toyota Camry Sedan (A51694)
2015 Toyota Camry...
