Hydraulic line size.
   / Hydraulic line size. #1
Swblack1216
Washington state
Kioti ck25, Ford 4500
Hello I am getting ready to replace all hydraulic lines on my 4500 tractor 4500 tbl . Try to get Idea of how much it will cost.Would like to order standare length premade.Any idea so on sizes ID I have service manual. Does not tell me.
   / Hydraulic line size. #2
All of mine kinda blew up at once. I had to take them off and measure them and write down the fittings. Many hydraulic shops and some auto supply shops can build you new cables. Don't skrimp on good cable material. Most shops will give estimates over the phone, but with all the loader cables, it will not be cheap.
   / Hydraulic line size. #4
Nope. You need custom hoses the exact length.
Premade stuff is usually in 6" or 12" increments.....and you dont want to be too short (obviously) but too long is also just as bad on a backhoe. Everything is tight and you dont have room to "waste" 8" of extra hose somewhere that isnt needed.
And besides that....most "premade" hoses have JIC fittings that match the hose size. IE.....1/2" hose and 1/2" (-08) Jic ends. And Im pretty sure most them old ford backhoes upsized the fitting one notch. So a 1/2" hose would have a 5/8" JIC end crimped on.
And when it comes to backhoes....hose routing can be a PITA. Do the hoses one at a time OR tank VERY detailed drawings, pictures, and label EVERTHING.
But for them ones that are tough to route.....or some that run through the boom or swing post......when you pull out the OLD hose (because you need to do that to take a measurement)....while pulling the hose out, have a string tied to the other end so that the string ends up in place of the hose.
When installing the new hose, tie one end to the string and pull it back through.
   / Hydraulic line size. #5
There are some guide charts available to help know your JIC fittings and hose. Have sourced good hoses from Surplus Center that have high quality extra tough hoses. Depends on the ends wether you can adapt or need custom ends or lengths. After a few hoses broke, did all the hoses from Surplus Center for a Kubota B20.
A good hydraulic shop can be helpful too. Use your phone for pictures and notes when replacing lines.
Always worried about replacing the lines going from the tractor to backhoe boom on my 4500. Luckily they never broke. Think it does take some special wrenches to make/break some connections.
2008 Ford E-350 Versalift 29N 29ft Bucket Van (A50323)
2008 Ford E-350...
2005 Peterbilt (A50120)
2005 Peterbilt...
2004 Ford F-250 XL (A50120)
2004 Ford F-250 XL...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
2018 Caterpillar 416F2 4x4 Extendahoe Loader Backhoe (A50322)
2018 Caterpillar...
2012 Ford Expedition XLT 4x4 SUV (A50324)
2012 Ford...
