Hydraulic Line Issue
   / Hydraulic Line Issue #1
Buffalo Trace
Nashville, TN
Kubota
Hello All - I have a BX2370 and I cannot attach the red FEL loader hydraulic line. It has always been fairly easy in the past. There is a small dent on the metal at the end of the hose, but it doesn't seem that would make a difference, but from what I can tell, nothing else has changed.
Any idea what is causing it not to want to attach? I have tried pushing on the nipple with a screw driver and the nipple is not stuck.
It is very frustrating.
   / Hydraulic Line Issue #2
Pressure. There is pressure built up in the lines that you need to release. Turn off tractor, move joystick all around for the tractor side. Take two wrenches and a rag and loosen the fitting on the loader side to let a small spurt of fluid out-it will connect right up after that.
Okay, I'll try that - thanks for responding.
2013 RAM 4500 (A50323)
2013 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A52377)
2013 Chevrolet...
RHINO DB150 LOT NUMBER 73 (A53084)
RHINO DB150 LOT...
1965 Rodgers T/A Equipment Trailer (A53117)
1965 Rodgers T/A...
2012 VOLVO BL70B BACKHOE (A51246)
2012 VOLVO BL70B...
2011 FORD F-450 (A52472)
2011 FORD F-450...
