Hydraulic lift troubleshooting
   / Hydraulic lift troubleshooting #1
Pingman
My 1320 is making a funky noise every 10 secs or so, and when I attempt to raise the 3-pt, the noise is constant and there is a 5 second or so delay before the 3-pt lifts.....any ideas? Thanks
   / Hydraulic lift troubleshooting #2
Got a suction leak/ and it is loosing prime / having to reprime / cavitate? What's it sould like.. a squeal/ rumble? popping? etc.
Soundguy
sounds like a hog squealing
   / Hydraulic lift troubleshooting #4
Lots of times squealing is a relief valve.. however in your case I'd almost guessit was air being purged.. sounds like you may have a leaky lift that takes a second or so to prime when you go to use it.. etc.
Soundguy
The problem was fixed by simply changing the hydraulic filter /forums/images/graemlins/grin.gif
   / Hydraulic lift troubleshooting #6
Suction side? Could have been pump cavitating due to oil starvation.
Soundguy
Club Car Electric Utility Cart (A51694)
Club Car Electric...
Deere 9965 Cotton Picker (A52748)
Deere 9965 Cotton...
2000 Gallon Fuel Tank W/Pump (A50774)
2000 Gallon Fuel...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2013 Mack GU713 T/A Roll-Off Truck (A50323)
2013 Mack GU713...
New Holland 273 Square Baler (A50774)
New Holland 273...
