Hydraulic leak
/ Hydraulic leak #1
hagman
Central, IL
B7610 Kubota
Hi All,
Reattached my FEL this weekend on my B7610 and one of the quick connects is leaking. I looked but it appears to be snapping into the groove and I can't pull it out from the controle but I can hear and see it leaking fluid. Before I replace the connnector does anyone have any other things to check first?
Hagman
/ Hydraulic leak #2
Depending where its leaking from, from what you say, if I read this right, its leaking where it couples together. Relieve all pressure from system and disconnect them and clean real good and re-connect and keep your fingers crossed. LOl
Jim
/ Hydraulic leak #3
Check and see if you have O rings in the female connectors, if so could be mangled or split. All mine leaked unti I replaced the O rings.
2025 B and B Fabrication CT3500MRT Towable Reel Tensioner (A61572)
2025 B and B...
2012 MACK GU713 DUMP TRUCK (A63276)
2012 MACK GU713...
CASE 105C (A62177)
CASE 105C (A62177)
JCB 92" Clamshell Bucket (A64119)
JCB 92" Clamshell...
2021 ASV RT-40 Compact Track Loader Mini Skid Steer (A61572)
2021 ASV RT-40...
BALDOR INDUSTRIAL 15 HP MOTOR (A64281)
BALDOR INDUSTRIAL...
