Lloyd_E
Veteran Member
- Joined
- Nov 15, 2003
- Messages
- 1,475
- Location
- South Shore Nova Scotia Canada
- Tractor
- 2008 Kioti DK 45 sc
Smelled hydraulic fluid and noticed some on left rear tire - inside.
The return line to the block was leaking a bit - tighten. Did a bunch of manure moving and checked for leaks every so often... looked OK. Moved some sand this morning and could smell it again. Stopped tractor and looked - leaking again. I wiped everything clean and moved loader up and down and rechecked. Found the leak. Hose was rubbing against bolt that holds cover in place on floor of cab. See attached.
I am not very mechanical but am willing to follow directions and learn.
So having said that is this the correct way to proceed.
1/ lower back pto, lower loader - will this take pressure off of line?
2/ position buckets under each connection
3/ Undo hose connection... may have to lower block below cab to access connection.
4/ Replace hose - hopefully local truck dealer can manufacture hose for me.
Reverse the above - top up fluid.
TIA.
PS: sorry for the crappy images...
TIA.
