Hydraulic leak
   / Hydraulic leak #1
khamill2000
Bronze Member
central Kansas
Mahindra 2815 HST
I know I said I was only going to ask 1 question per day but this one is really for the dealers.
Had this tractor 3 days now and noticed some seepage from the right front bucket hydraulic. Quite a bit of seepage. Is this covered under warranty and how do I go about getting it fixed if it is?
   / Hydraulic leak #2
If it is leaking at a fitting, try tightening the fitting (if you haven't already). If that doesn't fix the leak, or if it's leaking around where a rod comes out of a hydraulic cylinder, then call the dealer.
A new tractor shouldn't be leaking in three days.
   / Hydraulic leak
Thanks. It's at the seal where the rod comes out so I will call in the morning.
   / Hydraulic leak #4
Yes, it's covered under warranty. 1 year "bumper to bumper" warranty and the next 2 years it's your engine and drivetrain.
If it's leaking from where you are saying, I'd take it to the dealer and let him further inspect the leak. Never seen one leak from there before though, most loader leaks I've seen are the hyd. lines going from the valve to cylinder.
2021 ASV RT-135 Forestry Posi-Track High Flow Compact Track Loader Skid Steer (A50322)
2021 ASV RT-135...
2006 Komatsu PC400LC Hydraulic Excavator (A50322)
2006 Komatsu...
toro turf sweeper (A50324)
toro turf sweeper...
Bestway Ag 3pt 55 Gal Spray Rig (A50120)
Bestway Ag 3pt 55...
Hunter GSP9712 Tire Balancer (A50121)
Hunter GSP9712...
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,400lb 3 Ton Crane Service Truck (A50323)
2014 Ford F-550...
