Hydraulic leak problem JD 300 Industrial
   / Hydraulic leak problem JD 300 Industrial #1
hamp34
cardington ohio
JD 300 Industrial tractor
Hi everyone!
I have a jd 300 Industrial tractor backhoe and loader I am having a leak from the pressure control valve I have replace every seal / o-ring on the valve and it still looks like it is leaking from the casting Has anyone had a casting pinhole / crack in that valve before?
It is leaking from where the black arrow is pointing which is behind the little alcove SAM_7411.JPGSAM_7412.JPGSAM_7417.JPG
   / Hydraulic leak problem JD 300 Industrial #2
Without checking further, but reminds me of the fitting someone was talking about a couple days ago.. that had a couple o-rings between the casting and the fitting.
The OP was asking to help identify the fitting (think decided it was a flow control) and if there was a gasket leaking.
What have you found behind this control valve? gasket or o-ring?
o rings are behind the valve and all of the seal / o-rings have been replaced it is not leaking from any line attaching point
   / Hydraulic leak problem JD 300 Industrial #4
I had a pinhole leak like that in my JD 400 Industrial. My Bro-in-Law welded it for me.
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2018 KENWORTH T680...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
2021 TAKEUCHI TL8R2 SKID STEER (A51246)
2021 TAKEUCHI...
New/Unused Radiant Cooktop (A51573)
New/Unused Radiant...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
2002 Kenworth T800 Truck, VIN # 1XKDD49X72J898126 (A51572)
2002 Kenworth T800...
