Hydraulic issues: 755 With Bush Hog FEL
   / Hydraulic issues: 755 With Bush Hog FEL #1
hunter19707
Ohio
JD 755 and 2006 Cub Cadet Z-force 50"
I recently purchased a JD 755 with a 1846QT fel. Loader works fine, but after a while it will only go up partially. Then, if I crack open a fitting on the fel hydro lines and bleed fluid as I raise the fel, it will raise to the fully extended position again. Then the situation will repeat. The fel will not raise the front end off the ground either. I also noticed the power steering cylinder has a leaking seal, so I ordered a new cylinder which has yet to arrive. I plan on removing and cleaning the suction screen at the rear by the pto and replacing the hydro filter. I did notice a quick connect for one of the fel hydro lines leaking and I have since stopped the leak. Does anyone have any suggestions or ideas on what else I should do or what to check? Could air be getting into the lines through the leaking steering cylinder? This is my first tractor, I don't know much about them. So, any help is appreciated.
   / Hydraulic issues: 755 With Bush Hog FEL #2
I assume the bucket tilts in and out normally? If so then I believe you have a problem with one of the quick couplers for the raise and lower boom circuit. I would replace the male and female halves of the boom circuit and see what happens.
I was thinking about that. Possibly the one that was leaking fluid is probably letting air in. The hydraulic fluid stopped leaking after I worked the connector back and forth a few times, but maybe I should just replace it and see if that takes care of the issue. And yes, no problems with the tilt.
2025 Swict 66in Bucket Skid Steer Attachment (A53421)
2025 Swict 66in...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
2011 Case 3020 30ft Flex Draper Head WITH TRAILER (A53473)
2011 Case 3020...
