Loader HYdraulic issues 7310 loader
   / HYdraulic issues 7310 loader #1
Jerry Judge
Cherokee, alabama
NH 4835, MF255, 8N
Started to get down a roll of hay and loader would only go up about half way. By jiggling the joystick to tilt up and then raise you could get it all the way up. then the shocker. Get a 1600 pound roll on and it seems to work ok. Set it down and same thing. When it stops raising, none of the lines are rigid or under pressure. With the bale on I raised and lowered a number of times thinking air issue. Bale off and same deal. Also took all the disconnects off and put back. Same deal. Any one got any suggestions
   / HYdraulic issues 7310 loader #2
:welcome: to TractorByNet! :thumbsup:
Strange, still doing it?
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
20 STEEL FLAT SHEETS (A50854)
20 STEEL FLAT...
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
2015 VOLVO VNL TANDEM AXLE SLEEPER (A51219)
2015 VOLVO VNL...
2015 MACK GU713 (A50854)
2015 MACK GU713...
1982 LeeBoy Motor Grader (A51039)
1982 LeeBoy Motor...
