Macinnis
I have a new ls mt3 57 hp tractor as well as a new hydraulic side shift flail mower.
this is my first tractor, so keep that in mind.
while hooking up the flail mower, one of the two hoses did not reach the tractor. Since this was brand new, i wanted to test the shift (with only one hose connected) so i got in tractor and sure enough, the side shift in the flail mower moved to one side.
so i had a brand new hose made that was 2’ longer and had them put the correct nozzle up to the tractor on both hoses (one new hose and one old hose - the nozzle I installed to test was not on tight enough...they got them tight with some teflon tape).
so i go to install both hoses and i can see the hoses flex, but the flail does not shift to either side. Tractor was at 2000 rpms when i did this and all other hydraulics on the tractor work fine.
i even reversed the hoses thinking maybe the new hose was bad or whatever and still nothing. No leaking at either end of either hise either...
any thoughts on what could be wrong or what i can do to fix or diagnose the issue?
its a real pain now as the flail mower is all the way to one side ...so i cant even cut my pto shaft to the correct length until the flail is centered...gotta start cutting grass soon.
thanks!!!
thanks!!!
