Loader hydraulic hose replacement
   / hydraulic hose replacement #1
tciller
I have to replace a leaky hydraulic hose in my front end loader. Once replaced do I have to do anything to get the air out of the lines?
   / hydraulic hose replacement #2
Just run the cylinder(s) through a few complete cycles. That should purge the air.
I think Kubota finally corrected the design flaw on the tractors. I have now bent two of the fixed hydraulic lines that run across the front of my loader. This time since I was replacing a leaky flexible line I replaced the hard lines as well. I was at the dealer and noticed that Kubota now has a plate covering those hardlines. I may just get myself a piece of angle iron and drill holes in it where the plates hold the hardlines to cover them.
   / hydraulic hose replacement #4
Kubota suggests turning the steering wheel from lock to lock a few times to purge air in the system.
FIATALLIS MOTOGRADER (A50854)
FIATALLIS...
2023 Komatsu WA320-8 Articulated Wheel Loader (A49461)
2023 Komatsu...
19010 (A48082)
19010 (A48082)
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A49461)
Miller and Smith...
RIGID TOOLBOX (A50854)
WASTE OIL TANK (A50854)
WASTE OIL TANK...
