HYDRAULIC HOSE REPLACEMENT BT900 BACKHOE
   / HYDRAULIC HOSE REPLACEMENT BT900 BACKHOE #1
BOTAL35
MONTGOMERY , AL
95 KUBOTA L35
HAVE KUBOTA L35 W/BT900 BACKHOE HYDRAULIC LINES STARTING TO LEAK. NEED TO REPLACE THE LINE THAT RUNS TO THE DIPPER STICK CYLINDER. IS THERE A TRICK TO PULLING THE HOSE THROUGH THE SWING FRAME? THERE IS 6 LINES GOINGING THROUGH THIS VERY TIGHT SPOT PLUS THE LINES ARE INSIDE THAT PROTECTIVE SOCK. TRIED TO PULL IT THROUGH BUT IT GETS STUCK HALF WAY IN THE SOCK IF THAT IS THE RIGHT NAME FOR IT. ANY HELP OR SUGGESTION WOULD BE GREAT.
WORKSAVER RMB-325-PW LOT NUMBER 117 (A53084)
WORKSAVER...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
John Deere 2440 Tractor (A52384)
John Deere 2440...
2017 E-Z Beever M12R Towable Brush Chipper (A51691)
2017 E-Z Beever...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
