hydraulic hose, fittings, crimpers, and water transfer etc. questions,buy,sell.
   / hydraulic hose, fittings, crimpers, and water transfer etc. questions,buy,sell. #1
tophoseman35
Southeast
massey 231
Guys bring on the questions. I've been dealing with hoses, fittings, and etc for 15 yrs but i go into everyday knowing there is always something to learn. i have a vast knowledge of the industry and built hoses out in the field up to 2" ID 6000 psi in coal mines for hydraulic shovels. Granted I thought i just knew hoses until i did it out in the field and could see it all in action. Don't let anyone tell you that you can't crimp this brand or that brand with said crimpers because that is false. All you need is a crimp diameter and find a die the fitting fits securely in and that will compress smaller than given crimp diameter. I have used 2 different dies before crimping the same fitting. Companies pay engineers to crimp and test this brand with that private labelled hose, so when they tell you that this brand fitting will not work on this brand hose that is false as well. A weatherhead 2 wire will work on a gates 2 wire hose just crimp the right diameter and yes experience a field testing go along way in this. Safety is always first.There are only 7 hose manufacturers in the world outside of china so many many times you have various brand or manufactured fittings being crimped on the very select number of hoses. although many hoses have different names they are all manufactured by a select few manu plants and too many come from china. i know i sold chinese hose for 10 yrs and didnt realize it because the company i worked for has a Big tire brand name.
   / hydraulic hose, fittings, crimpers, and water transfer etc. questions,buy,sell. #2
Well if you are making hoses at the right price and are prepared to put them in a 20lb mailer box to OZ, I may be interested!
   / hydraulic hose, fittings, crimpers, and water transfer etc. questions,buy,sell. #3
The southeast? Like around Triabunna or Swansea?
   / hydraulic hose, fittings, crimpers, and water transfer etc. questions,buy,sell. #4
I'm surprised more people haven't taken you up on your offer for information. Here's one for you...
I'm new to hydraulics, and have a project that I need to change some hoses and rebuild some cylinders on. Before I dig in, I wanted to get the right JIC 37 caps and plugs to protect the system while I have hoses off, etc. However, I have no idea what size(s) I need. What's the best way (if it's even possible) to determine what size hose/fittings you have without removing a hose?
   / hydraulic hose, fittings, crimpers, and water transfer etc. questions,buy,sell. #5
I may have answered my own question, but I'd like confirmation. Here's my theory...
Since hoses are measured by ID, and tubing by OD, shouldn't I be able to just measure the OD of a piece of metal tubing connecting to the hose and find the dash size for the hose connected to it, and therefore the fitting also?
CFG Industrial SAII100 (A50123)
CFG Industrial...
2014 Ford Escape SE, Eco Boost (A52384)
2014 Ford Escape...
43029 (A51691)
43029 (A51691)
2022 Tracker Pro Team 190 TX Tournament Edition Ba (A53117)
2022 Tracker Pro...
2013 BIG TEX BIG TEX (A53843)
2013 BIG TEX BIG...
Bryant 650AN048-E A/C Unit (A52377)
Bryant 650AN048-E...
