IslandTractor
Super Star Member
- Joined
- Sep 15, 2005
- Messages
- 16,647
- Location
- Prudence Island, RI
- Tractor
- 2007 Kioti DK40se HST, Woods BH
My 2007 Kioti DK40se with 500hrs has been pretty much flawless since new. Hydraulics including two rear remotes and a diverter valve have been maintenance free other than routine fluid and filter changes.
Yesterday I mowed and grappled and then shut the tractor down normally. I disconnected the grapple hydraulic lines per routine in preparation for mounting a tree boom. This morning the tractor started right up and all hydraulics worked. However, as I was backing up it felt like I ran over a rock or small stump. Tractor went "bump" then it happened again a few seconds later. I dismounted and found no rock etc and as I was checking the tractor "bumped" again. I could see it jump slightly just as it would if you ran over a rock. Engine purring along at idle. About ten seconds later it happened again and this time I was behind the tractor and saw the 3PT arms move slightly in association with the bump. Flail mower mounted but not engaged. I checked the levers for 3PT and draft control and both were in middle and 3PT responded normally to lever. It seems the 3PT arms moved (caused) each bump. Hydraulic fluid is full. Bumping continued for five minutes and then stopped. Everything works.
Any idea what caused this?
