Hydraulic guestion
   / Hydraulic guestion #1
JWD1312
CHEYENNE, WYOMING
Kubota 7510
I have a 8hp brigs motor(vertical shaft) I'm going to put a 4gpm pump on it with flexible coupling. Do I buy a CW or CCW pump.
THANKS
   / Hydraulic guestion #2
Clockwise..
If using a coupling,look at the motors shaft and check the rotation.Buy a pump that rotates opposite...like looking into a mirror.
If belt driven and the pump and motor are on the same side of the belt,the rotation would be the same.
C'mon...whatcha building??? /forums/images/graemlins/mad.gif
2015 FORD E350 16FT BOX TRUCK (A52576)
2015 FORD E350...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
INSPECTION (A51572)
INSPECTION (A51572)
KUBOTA BX2350D TRACTOR (A51247)
KUBOTA BX2350D...
23222 (A50323)
23222 (A50323)
