Hydraulic GPM from DX33 (TC33D)
   / Hydraulic GPM from DX33 (TC33D) #1
Fanlo2300
Quebec Canada
Case IH DX33
I am considering adding a wood splitter on my DX33 (same as TC33D).
The specs for this tractor show a "Hydraulic Lift System Pump Capacity" of 7.6 USGPM.
Does it mean that I get this flow at the attachment connectors ? Or do I have to substract from this flow the power steering end other hydraulics ?
Thank you for you expertise...
   / Hydraulic GPM from DX33 (TC33D) #2
I'm not familiar with the specifics of your tractor but generally speaking, the steerring pump is separae from the main pump. and is rated separately. It alsohas smaller capacity. If I'm wrong, perhaps Jinman will correct me. He has a TC33 and knows them well.
   / Hydraulic GPM from DX33 (TC33D) #3
I have a TC33D and was considering a wood splitter for it at one point. Here are some thoughts I considered when I was trying to decide.
While I don't remember the specifics about the flow rate required for a log splitter I believe our 33D can do it but the travel time to split through a log and then reverse for the next log would be relatively long.
There is also the cost to consider. I decided to purchase a gas-powered splitter for about $1,200. From what I remember it will cost you that much, or more for rear remotes and the hydraulic splitter for your tractor.
The gas splitter I purchased can be used vertical and horizontal position. By having a separate splitter it gives me the independence of using the tractor's FEL to bring wood to the splitter. By setting the FEL to waist level and using the splitter in the horizontal position I'm able to slide logs from it onto the splitter without bending over. I can then put them back into the FEL or onto a pile without bending over.
The other point is do you really want to run your big 33 Hp diesel engine to drive a log splitter. What ware and tare are you putting on it rather than a cheaper to maintain/run gas powered splitter.
The gas-powered splitter is way more portable than your tractor. You can let your neighbor's borrow the splitter without loosing the use of your tractor.
   / Hydraulic GPM from DX33 (TC33D) #5
Your power steering is a separate system with it's own reservoir and pump. As a matter of fact, the reservoir sits right on top of the pump. I'm surprised you don't know that from doing routine maintenance.:confused:
Your main hydraulic flow of 7.6 gpm is in a perfect world. I'd guess your flow is probably likely to end up being more like 6.5 gpm or maybe about 5 gpm which is sufficient to run your splitter. The problem is you'll have to run your tractor at 2000 to 2500 rpm to produce that full flow capability. If you run at 1500 rpm, you may find the flow reduced to a point that it is too slow if you are a fast splitter. I run my TC45D that has about 2 gpm more flow than your tractor up to 2000 rpm when splitting with my 3PH splitter. That gives me the best speed. I'm not really that fast and if it's a little slow that suits me just fine. I can tell you that with my wife and I both feeding rounds, we stay very busy with our splitter. For the price, it's hard to beat a 3PH splitter.
BTW: Just because it's a 3PH splitter doesn't mean you have to run it that way. If you get much longer hoses, you can sit that splitter on a trailer beside the tractor and just hook up the hydraulic lines. Some people find this method more satisfactory.
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
MURRAY PUSH MOWER (A53843)
MURRAY PUSH MOWER...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2012 Audi Q5 AWD SUV (A51694)
2012 Audi Q5 AWD...
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
