Hydraulic gear pump advice
   / Hydraulic gear pump advice #1
tanner5340
Townsville, Queensland
Zetor 5340 (John Deere 2200)
Hi,
I keep getting large amounts of transmission/hydraulic oil in the engine oil, the only place it can enter the sump is through the connection between the engine and hydraulic pump.
I have replaced the shaft seal on the hydraulic pump twice with a non genuine seal that was matched up at a local seal specialist.
The question I have is: is it possible for the gear pump to wear internally enough that it over pressurizes the shaft seal?
NB: I have replaced the pumps 'E' seals as well, I'm wondering if the high pressure oil can pass through the gears.
   / Hydraulic gear pump advice #2
Yes they can force oil out of the seal and even dislodge the seal if there is enough internal leakage . Is there ANY wear in the housing or end plates where the gear have been touching them ? New Italian group 1 and 2 pumps are around $150 on ebay . Group 3 are around $400-$500 .
   / Hydraulic gear pump advice #3
Hallo new pump.......do not wast time on old pump or replacing seals in old pump
(INOP) NEW HOLLAND TS6.120 TRACTOR (A51247)
(INOP) NEW HOLLAND...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
2015 GMC Acadia SUV (A51694)
2015 GMC Acadia...
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
King Kutter TG72 Rotary Tiller Tractor Attachment (A51691)
King Kutter TG72...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
