Hydraulic Front Wheel Drive Wiring Diagram
   / Hydraulic Front Wheel Drive Wiring Diagram #1
rtlivioco
bacolod philippines
john deere 4020 hfwd
Hi I have John Deere 4020 HFWD Synchro here in the philippines which my parent bought. its a Diesel 6 cylinders. The tractor serial number at the back of the PTO the number states T213R 262552R , at the side of the engine the number states 6404 DR-01 315167R .
When I tried to look on it especially on the front drive . I found out that the HFWD connection was cut off. we tested the front solenoid thru the 3 terminals and it works since the tester moves . We are planning to rewire it and plan to revive the HFWD to make it 4 x4 if needed however we are challenge where to connect it. WE look up the parts catalogue and we could not find the switches and its location on this part number
AR49433,AR49432,R44017
trying to paste the picture of this however it wont
Catalog: 1116 | Grid: 2C11 | Section: 40 | Page: 28
Catalog Name: 4000 and 4020 (s.n. 201,000- ) Tractors
Page Name: POWER FRONT WHEEL DRIVE ELECTRICAL SWITCHES AND WIRING
KEY PART NO. PART NAME QTY TRACTOR SERIAL NO. REMARKS
1 AR53938 TOGGLE SWITCH 1 (SUB FOR AR45312) (NLA)
2 R44096 LOCK PLATE 1
3 R44097 NUT 1
4 R44094 LABEL 1 (NLA)
5 AR46062 SWITCH 1 -258409 ROTARY(NLA)
AR49433 SWITCH 1 258410- ROTARY(NLA)
6 R44025 NUT 2
12H292 LOCK WASHER 2 1/2"
7 21H1315 SCREW 2 0.164" X 3/4"
8 T19977 LOCK NUT 2 NO. 8
9 R42985 ARM 2
10 R42984 CLIP 2
11 R42986 BOLT 1 (NLA)
12 AR46063 SWITCH 1 -258409
AR49432 SWITCH 1 258410- (NLA)
13 14H1076 NUT 2 3/8"
12H304 LOCK WASHER 2 3/8"
14 R49785 ROD 1 (SUB FOR R42987) (NLA)
15 AR45316 BALL JOINT 2
16 12H246 LOCK WASHER 2 0.190"
17 19H2284 CAP SCREW 2 3/8" X 7/8"
18 R49784 BRACKET 1 (SUB FOR R42988) (NLA)
19 AR45390 WIRING HARNESS 1 (NLA)
20 AR45734 WIRING HARNESS 1
A5172R CLIP 1
R41439 GROMMET 1
21 R44016 STRAP 1
22 SPACER 1
23 AR49281 BRACKET 1 (SUB FOR AR45238) (NLA)
24 R44017 SWITCH 1
25 19H1800 CAP SCREW 1 3/8" X 1-1/2"
12H304 LOCK WASHER 1 3/8"
26 21H1348 SCREW 2 0.138" X 1-1/8"
12H321 WASHER 2 0.138"
27 AR49342 WIRING HARNESS 1 (SUB FOR AR45389) (NLA)
R41439 GROMMET 1
.. R44302 TIE BAND AR
   / Hydraulic Front Wheel Drive Wiring Diagram #2
Is this the parts photo you were trying to post????
   / Hydraulic Front Wheel Drive Wiring Diagram #4
I've never been around a HFWD but it appears the 2 switches( AR49433 & AR49432 ) are associated with the shift mechanism as in fwd/reverse. BUT I'm probably wrong.
I look on the shift mechanism and your are correct , the two switches are attach their.However when I inquired thru john deere parts the two switches are no longer available for sale. could their be another way we could not use those switiches and put in a toggle switch instead if we will use the power front drive?
   / Hydraulic Front Wheel Drive Wiring Diagram #6
diagram for john deere 3130 hyd assist front wheel drive
   / Hydraulic Front Wheel Drive Wiring Diagram #7
:welcome: to TBN
That be the wiring diagram you want?
   / Hydraulic Front Wheel Drive Wiring Diagram #8
Hi
I am also looking for same wiring diagram, trying to repair father's 3130 HFWD.
2025 SDLANCH SDLD25 UNUSED Crawler Dumper (A53117)
2025 SDLANCH...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
Rock wood travel trailer (A51694)
Rock wood travel...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
Genie GTH-644 (A50490)
