I have a Mitsubishi D2000ii with front end loader. Used for light farm work and bush hogging my pasture. What hydraulic fluid would you recommend I use in it?
If your tractor has a common sump for the transmission, differential, and hydraulic system, use UTF or THF type oils.
If the hydraulic reservoir is separate then use regular hydraulic oil type AW.
