Hydraulic Fluid
   / Hydraulic Fluid #1
Thats Hot
Bronze Member
Ocala Fl.
Kubota, B2630
I have a Kubota B2630, can I use offbrand fluid or do I need to use just Kubota's brand ??
   / Hydraulic Fluid #2
Everyone will have an opinion. Mine is you should use the Kubota fluid, especially if it is a HST. Several owners have reported issues with their hydrostatic equipped machines when not using the Kubota SUDT or SUDTII fluid. Especially if you live in a cold climate.
   / Hydraulic Fluid
Ok thanks..
   / Hydraulic Fluid #4
No experience with HST. Everything I have is gear. And everything gets traveller brand stuff from TSC.
   / Hydraulic Fluid #5
I have a Kubota B26 TLB and I used the Kubota UDT in it at first change but switched to Triple S Universal hydraulic fluid at last service. I cant see any difference in the two. As KOua said, if you are in really cold climate, you may want to use the SUDT2 full synthetic for better performance in extreme cold. Anything above 15F any brand will work just as well as the UDT.
Another issue is warranty: keep the Kubota oil in as long as you are under warranty just so they don't have any issue with using different oil. MY Kubota dealer's service manager told me this and also told me that I could use Universal oil after warranty and I would not have any problems.
   / Hydraulic Fluid #6
I switched to Traveller as well. It was about 1/4 the price. I could tell no difference.
BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD-78HF...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2021 CATERPILLAR 926M WHEEL LOADER (A52705)
2021 CATERPILLAR...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A54313)
2012 INTERNATIONAL...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
