WVBill
Veteran Member
I'm moving over to this forum from the Attachments forum because it is more relevant.
I have a 197X Kubota B6100DT (Gear tranny). The operator's manual that came with it (B5100/B6100/B7100 Operator's Manual) says to use SAE 80 gear oil in the transmission/gearbox.
Kelvin's operator's manual from his later model B7100 (also a B5100/B6100/B7100 Operator's Manual) says to use hydraulic fluid (recommends Kubota UDT and several others as the first choice but also says that SAE 80 gear oil can be used.
Knowing nothing about oils and lubricants, I'm surprised that hydraulic fluid and gear oil seem to be interchangable in a transmission/gear case.
Isn't there a fundamental difference between hydraulic fluid and gear oil? I would think that Hyd Fluid is made for the transmission of pressure with any lubricating function secondary. Where as gear oil is made to lubricate gears, not necessarily under pressure and when it is used to transmit pressure (e.g. my 3 ph) it is secondary.
Can anyone shed some light or am I way off base?
Bill
Bill
