hydraulic fluid temperature
   / hydraulic fluid temperature #1
tiverton
tiverton, ri
JD300, IH385, ford755A, massey harris pony, farmall BN
I have a JD300 (industrial, cousin to the 1020 model I believe) with power steering. I have noticed that the power steering valve housing (steering column) gets warm to the touch; perhaps 125 degrees F. Is this normal and consistent with the temperature of the hydraulic fluid pumped throughout the tractor?
   / hydraulic fluid temperature #2
125 degrees is not hot at all for hydraulic fluid, many times it will run 160-180 or so.
Ben
   / hydraulic fluid temperature #3
Sometimes "normal" is considered to be 100 degrees F above ambient temperture. That's pretty hot for most of us; certainly too hot to touch.
2024 Bintelli ActivEV Pulse Electric Golf Cart (A51694)
2024 Bintelli...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
2014 Ford Escape (A50323)
2014 Ford Escape...
2015 Ford F-450 Knapheide Service Truck (A51692)
2015 Ford F-450...
2017 Rogator RG1300B Dry Fertilizer Applicator (A52748)
2017 Rogator...
Kinze (Delgelman) MT 201 High Speed Disc (A52349)
Kinze (Delgelman)...
