Hydraulic Fluid Recommendation
   / Hydraulic Fluid Recommendation #1
V1BuzzBomb
Seacoast, NH
John Deere 110 TLB
I have purchased a DR 3PH splitter to run off my JD 110 TLB. I am running, at least temporarily, a filter on the return side from the splitter for the first few cycles. I strongly suspect the splitter and valve to be dry upon purchase. I additionally plan to blow out the supplied hoses prior to install.
As I initially cycle the splitter system, I will drain some of the tractors reservoir to purge/prime the splitter system. Obviously, I will have to top off the tractors reservoir.
I have NAPA, Tractor Supply and a large truck repair facility near me to acquire the fluid. What recommendations on preferred hydraulic fluid, brand, name, etc.?
   / Hydraulic Fluid Recommendation #2
I'd check over on the oil forum, lots of discussions on this kind of thing. There are specs for oil, as long as what you buy meets that spec it's fine.
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
2018 MDB LV600 GREEN CLIMBER SLOPE MOWER (A51406)
2018 MDB LV600...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2001 MACK CH613 DAY CAB (A54313)
2001 MACK CH613...
2016 Ford Transit 250 Cargo Van (A55788)
2016 Ford Transit...
JOHN DEERE 3032E TRACTOR (A54756)
JOHN DEERE 3032E...
