hydraulic fluid leaking onto drive clutch john deere 1530
   / hydraulic fluid leaking onto drive clutch john deere 1530 #1
wrangler95
procious, wv
john deere 755 and 1530
Quick question. If hydraulic fluid is leaking from power steering and getting on drive clutch will it ruin clutch material?
   / hydraulic fluid leaking onto drive clutch john deere 1530 #2
PROBABLY or will cause clutch disk to slip. How did you determine PS is leaking into CH?
From looking in the clutch inspection holes everything in there looks wet, but it doesn't look like engine oil. The steering motor was replaced with used one before I bought it. Right after I started having trouble with loader and PS it seems like the clutch is not disengaging all the way. When I shift from neutral to any gear it will I have to lower rpm's and put in gear easy, when it does go in tractor jumps.
   / hydraulic fluid leaking onto drive clutch john deere 1530 #4
Leak could also be trans input shaft seal.
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
UNUSED AGT KRW23 WHEEL LOADER (A51247)
UNUSED AGT KRW23...
2023 John Deere 8R410 MFWD Tractor (A53472)
2023 John Deere...
UNUSED HURRICANE G350 MINI CONCRETE MIXER (A51248)
UNUSED HURRICANE...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
City of Buckhannon - Kawasaki 4010 Mule (A52384)
City of Buckhannon...
