Hydraulic fluid leaking from 345 tractor
   / Hydraulic fluid leaking from 345 tractor #1
Bheiser
John Deere 345
I started up the tractor yesterday and noticed that there appears to be hydraulic fluid leaking from the front of the motor.
This is a water cooled 20 HP Kawasaki motor.
The fluid doesn't look like coolant. it's slippery like Hydraulic fluid.
This tractor has hydraulic deck and steering.
Any ideas on what could be leaking and how to repair?
Thanks for any insight.
   / Hydraulic fluid leaking from 345 tractor #2
Welcome to TBN
First, I'd try to tie down what fluid it is.. engine oil, hyd. oil, or coolant.
And/or locate where the leak is coming from.
Valve cover maybe?
As you explore to find it, take some pics and post when you have a visual of the leak.
It's hyd. oil. I'll have to take the engine cover off to get a better look at where it's coming from this weekend.
Finally had the chance to look at it. It is cooling fluid. It only leaked when I start it up. It stops and doesn’t leak while I cut or pickup leaves for over an hour.
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
CAT 973 (A47384)
CAT 973 (A47384)
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
Wanco 800W Solar Integrator Trailer (A51691)
Wanco 800W Solar...
