hydraulic fluid leakage question
   / hydraulic fluid leakage question #1
bruski
Bronze Member
rural Missouri
Kubota b2400HSD
When I use the LA351 loader on my b2400 I get a little leakage from a couple of the quick couplers at the control valve. Is this something I should be concerned about or is it to be expected?
Bruski
   / hydraulic fluid leakage question #2
Bruski,
I have a BX2200 with a front mounted snowblower and it uses the FEL valve. I've had two instances of leaks; one as a result of a busted fitting, the second as a result of a loose fitting(at the pipe threads). Otherwise, my fittings don't leak. The fittings on my B7800 FEL system do not leak.
Turns out three of the quick connectors were bad. Dealer replaced them at no charge as they were a little embarrassed to have sold me the tractor with them leaking.
Bruski
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
SCAN TO RECEIVE TEXT UPDATES (A51248)
SCAN TO RECEIVE...
MCDON D60 HARVEST HEADER (A51247)
MCDON D60 HARVEST...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A51247)
UNUSED CFG...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
