hydraulic fluid in oil?
   / hydraulic fluid in oil? #1
bob sullivant
topeka ks.
kkubota b7200 hst
I have a b7200 Kubota HST that is leaking more and more hydrauliic fluid and I can't locate the leak. Now the engine is blowing oil everywhere. The crankcase is quite overfull. I don't smell diesel in the oil so I suspect the hydraulic pump is leaking into the crankcase. I could use some advice.
   / hydraulic fluid in oil? #2
Sounds like you are right to me. You can replace the seal, but in my experience it will only be temporary, the best solution is likely to replace the pump.
Brian
Thanks for responding even if you didn't tell me what I wanted to hear. I visited the dealer today and learned a new pump is five hundred bucks. The parts man showed me an exploded view of the pump. Guess I will jerk the pump off and see what it looks like.
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
1 Bridgestone 255/70R 22.5 and 1 Toyo M-872 12R 22.5 Tires (A51573)
1 Bridgestone...
2012 Altec WC126A Chipper S/A Trailer (A51691)
2012 Altec WC126A...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
2005 Ford Taurus SE Sedan (A51694)
2005 Ford Taurus...
