Oil & Fuel hydraulic fluid filter
   / hydraulic fluid filter #1
jkg1374
Brenham, Texas
Kabota B8200
Can u tell me where the hydraulic fluid filter is on the Kabota B8200?
   / hydraulic fluid filter #2
Just wanted to say HI and WELCOME, I'm sure the Kabota drivers will help you with that question.
   / hydraulic fluid filter #3
Its a spin on like a car oil filter located on the left side below the seat in front of the battery. Your hand practically hits it when you disengage 4 wheel drive or engage your rear PTO low speed. According to the service manual you remove 4 bolts to take off the cover before reaching the spin-off filter.
Apparently it can be changed independent of changing the fluid.
There is also a an internal screen that is supposed to be cleaned when the fluid is changed.
   / hydraulic fluid filter #4
That is where the filter is if it is a hydrostat. If not it only has a suction screen, and you are correct it should be removed and cleaned when changing the hydraulic oil.
Brian
Oh and if it is a hydrostat, it has two suction screens one for the hydraulics the other for the hydrostat.
UNUSED MOWERKING QUICK ATTACH BRUSH CUTTER (A51244)
UNUSED MOWERKING...
UNUSED FUTURE SKID STEER SIDE SHIFT FORKS (A51244)
UNUSED FUTURE SKID...
2011 INTERNATIONAL PROSTAR +122 6X4 DAYCAB ROAD TR (A51243)
2011 INTERNATIONAL...
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A52128)
Kubota SVL65-2...
RING 3 STARTS HERE @ 9:30 AM (A51244)
RING 3 STARTS HERE...
