Hydraulic fluid entering engine when using three point attachments under load
/ Hydraulic fluid entering engine when using three point attachments under load #1
Theobuck
Woodland, Ca
Iseki TU 180 4x4
Help please! I recently bought a used Iseki TU 180 4x4 compact tractor and have been having problems with hydraulic fluid filling the engine crank case when using the rear 3 point setup. The seller took the hydraulic pump and had it rebuilt but the problem reoccurred soon after. I did some trial and error to get more information and switched some hoses around on the 3 way spool and thought I narrowed it down to to left (inside lever). I replaced the spool assembly along with one of the feeder hoses and thought it was fixed. Alas, after using the box scraper and loader quite a bit with no issues, I installed and post hole digger on the rear and began drilling fence post holes and the case filled up again. I did get the auger stuck a couple times and loaded the 3point pretty hard. Any advice on that to try next would be awesome!
/ Hydraulic fluid entering engine when using three point attachments under load #2
I'm not familiar with Iseki tractors but I don't see how that's possible unless the hydraulic pump is attached to the engine block and the pump is leaking. Does the tractor have any oil coolers that may have been miss-assembled?
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
2018 TAKEUCHI TB240 EXCAVATOR (A64279)
2018 TAKEUCHI...
2014 Nissan Murano (A61574)
2014 Nissan Murano...
2014 Mercedes Benz CLA 250 Sedan (A61574)
2014 Mercedes Benz...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
Amadas SPC-6 (A64119)
