I have a Howard Price Hydro-Power 180 mower and recently it blew a steel hydraulic line that runs the mower decks. I had to half disassemble the cab to get at the line. I replaced it with a flexible line since there was no way to replace it with a steel line without removing the entire top half of the unit.
Well, you can guess that under pressure I lost a lot of fluid. I do not have the manual for this mower but found a link that states this uses AFT F fluid for the hydraulics. My question is, is a universal Trans-Hydraulic fluid compatible with this? The unit holds 37 gallons of fluid and since I have other equipment that uses standard trans hydraulic fluid I have it in bulk. No one around here has ATF F in bulk other than buying it by the case of 1 quart bottles.
Would the Mills Fleet-Farm Universal Trans-Hydraulic fluid be fine to use in this?
