Hydraulic fluid change with backhoe
   / Hydraulic fluid change with backhoe #1
dwalk19
Addison, ny
2018 LS XG3140H TLB
I have a backhoe on my tractor and assuming theres no real way to drain fluid out of backhoe cylinders, I'm coming up on 150hr service and was just thinking you pretty much just let it mix in with the new I'm assuming
   / Hydraulic fluid change with backhoe #2
Their is no practical way to change the fluid out of any cylinder in the system. If one were totally OCD they would have all cylinders closed before changing the fluid. It’s splitting hairs as it’s a small amount of fluid relative the the 10–15gallons in the system.
Yeah thats pretty much what I figured also
   / Hydraulic fluid change with backhoe #4
Mine was fairly contaminated when I got it so I raised the loader and hoe, pulled the drain plugs, then lowered lowered everything, pushed stabilizers down etc, so got extra crap fluid out of all the cylinders that I could.
LOT NUMBER 146 (A53084)
LOT NUMBER 146...
New/Unused 7ft 35 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 35...
Airco Tig Welder (A51691)
Airco Tig Welder...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
