Hydraulic Fluid Change On Farmall 45 with HST
   / Hydraulic Fluid Change On Farmall 45 with HST #1
rebelback
Bronze Member
South Arkansas
2010 Case Farmall 45 HST
My 2010 Farmall 45 manual states it takes 9.6 gallons of Hytrans Ultra. I followed the manual for my first hydraulic fluid change this weekend. I pulled both drain plugs, let it drain, replaced the HST filter, and replaced the hydraulic filter. Upon refill it was full at 7 gallons. I did start the change with the loader at full height. When I lowered it I was able to push out more fluid via the drain holes. I'm assuming, though, that there is still 2.5 gallons stuck in the hydraulic lines somewhere. Should I be worried about leaving 2.6 gallons of old fluid in the tractor?
2008 CATERPILLAR D6K LGP PIPE LAYER (A50854)
2008 CATERPILLAR...
2013 Ford F-250 Ext. Cab Pickup Truck (A50323)
2013 Ford F-250...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
Wells Cargo Enclosed Trailer (A50324)
Wells Cargo...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A51039)
2022 New Holland...
2006 PETERBILT 379 DUMP TRUCK (A51222)
2006 PETERBILT 379...
