hydraulic fluid change ford 3600 diesel
   / hydraulic fluid change ford 3600 diesel #1
kylennie
fairdale
ford 3600
where is the hydraulic oil drain plug on the ford 3600 ? also where is the fill plug ? what is the correct hydraulic oil for my tractor ?
   / hydraulic fluid change ford 3600 diesel #2
Those are very good tractors.
But...
If you can afford the tractor you can also afford the manuals for it.
Buy an I&T FO-41 manual - about 120 pages and will show you how to maintain and repair your tractor.
Also buy an owners manual. They can be bought new or used on Ebay.
It too is chock full of usefull information.
   / hydraulic fluid change ford 3600 diesel #3
When in the seat the Oil Level plug is behind your left foot. 7/16" square head Plug.
There is a large cap on top Right of the Diff that you open to fill/add.
2006 SHOP BUILT SINGLE AXLE 7-VALVE PUMP TRAILER (A45046)
2006 SHOP BUILT...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A42744)
2021 Ford F-150...
2005 MACK CX (VISION) (A45333)
2005 MACK CX...
2010 IC Corporation PB105 Bus (A42742)
2010 IC...
New/Unused 20ft x 20ft Container Shelter (A44391)
New/Unused 20ft x...
2016 Ford F-350 4x4 Utility Rail Truck, VIN # 1FT7X3B69GEC57510 (A44391)
2016 Ford F-350...
